| | | Forums66 Topics128,180 Posts1,057,158 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2024 Posts: 221 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 221 | I pulled the cover off to remove my wiper motor and I’m not sure if people put insulation in that area. It does appear to be an old mouse nest. Just seeing if anyone puts insulation up there? Then I would. Thanks | | | | | Joined: Sep 2009 Posts: 6,013 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,013 | Just my $.02 worth, but I wouldn't put any insulation in that space. It would likely trap/hold moisture causing potential rust damage that would could go unseen until it starts showing through from the inside out.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2024 Posts: 221 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 221 | Great. Thanks. I don’t much like it in there a mess to clean. Can I also lube hinges for windshield through this area or do I need to remove molding on outside of windshield. (Or do I need to start new thread). | | | | | Joined: Sep 2009 Posts: 6,013 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,013 | Ponchogl - Your new question about the lubricating windshield hinges should fit in this forum just fine considering they appear to be accessed through the wiper access cover area. I'll leave the answer on how to access and lube the hinges to fellow Bolters with 1941-46 trucks as they will know more than I do about that topic.
