6 members (Hotrod Lincoln, GMCJammer51, jmoore, Forty9, 2 invisible), 117 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
I'm thinking about getting the gas tank out of the cab and putting it somewhere within the frame. Who used what, And where did you put it?
My truck is a 1953 Chevrolet 3600 5 window P/U.
This is how mine is set up.
1941 Chevy YR 1.5 ton Dump Truck
Follow this restoration in its DITY Bay
Semper Fi
What are you working on Elmo? That info might get you some more helpful responses.
I used a tank from a 1970 Blazer for my 58 3200. It fit pretty much perfectly between the frame rails behind the axle.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Elmo, I used 2 Pontiac Fiero tanks, 10 gallons each. They fit perfectly between the frame rails and parallel to the drive shaft. My spare tire remains where the factory intended it to be.
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Apparently you can buy brand new ones. Whoda thunk it?
$450 each, though. $525 for the later years.
1950 Chevrolet 3100 (Ol' Roy)
Otto, when I did this 25 or so years ago, Fieros were pretty plentiful in the salvage yards….I think I paid like $75 each for them.
"Old Blue"
More pix on Flickr
Ya , that's why I looked it up. It won't be too easy to find a Fiero in a junkyard today.
That's a heckuva plumbing job, Flat.
How did you rig the fuel gauge? Is there a transfer pump or something? Is the filler neck still in the side of the cab?
Otto, I’ve got a rocker switch wired up so I can toggle to the fuel level sender in either tank. The driver side tank is the primary tank with its in tank pump delivering fuel to a GM TBI system I’ve grafted to a 327 CI V8. When the primary tank gets low I’ve got another switch which operates an in tank transfer pump in the passenger side tank to feed fuel back to the primary tank. Filler neck is under the bench seat at the driver side. I’ve got to open the driver door to fill ‘er up: both tanks simultaneously.
"Old Blue"
More pix on Flickr
this a TF truck but the other AD is pretty much the same.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
W Online: Content
It really matters what model you have. A lot of the information is for 3100 series and their frame rails are far enough apart for the Blazer tank as noted by Fibonachu but I have a 3600 and the frame rails are significantly different width in the area where you would deisre to install the tank. I used a 16 gallon tank from Tanks Inc.
1949/50 3600 Project
Follow in Project Journals
24601
24601
Elmo ... Just a question .... Why relocate the fuel tank?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Just curious, is there a cross-over line between the tanks or do you use one tank until it's empty and then switch to the other?
How did you rig up the fuel gauge?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike, I don’t have access to my diagrams just now, it’ll be a few weeks before I can get back to you. The dual fuel tanks took on a life of their own and I over-engineered it.
"Old Blue"
More pix on Flickr
Elmo, I'm hoping all the chatter in your thread hasn't sidetracked your original topic question. Perhaps a reply to John M's question on why you want to relocate the tank might help get things back to helping you out? headscratch Come on back and let us know so we might better offer suggestions/solutions. wink
~ Dan
1951 Chevy 3 window 3100
John Milliman, Too have more room behind the seats.
Elmo, Here is an older thread by Montana 54 Chevy that is right on topic to your question! Hope this might offer some further info and insight. smile
~ Dan
Gdads51, Thank you very much!
W Online: Content
Elmo, not sure where you are located in WI but if you want to see mine in person it would be a great chance to meet and talk trucks. My bed is currently off so it is easy to see the tank mounting and envision how I am running the filler (passenger side rear fender, not in the bed).
Im going to head up to WICruiser"s place and checkout what he did.What he did is what Im looking to do.
24601
24601
Elmo -- Thanks. That's a fine answer! Works for me. Hope the gang gets you figured out.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Elmo, Sounds like an outstanding plan! Appreciate if you guys come back and share the story and maybe some pictures of your meet up and results of your visit. thumbs_up
~ Dan
Will Do
