0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
Waiting on additional parts, new vacuum lines, new phenolic spacer reqd to clear fitting in manifold for pcv.
Will give full review once it's running.
Just a side note on Holleys destructions.
Diagram shows a 40-100 micron pre filter and a 10 micron post filter. The supplied wix 33033 is 20 micron and is labeled as pre filter in an online destructions from holley. The post filter supplied has no manufacturers name on it. Has a 2 different part numbers one on the box and one on the filter. Plugging in the number on the filter on the interwebs gets you to some Holley online PDF file. The file gives you a numbered parts list
The post filter cross references as a Napa gold filter whi ch is a wix filter 33482 which is a 10 micron. Go figure having to do some interweb sleuthing.
7
7 Offline
I don't think I would complain, looks like they did a good job with included parts, much better than most things now-a-days.
I've dealt with Holley products on almost all my projects.
Not complaining just an observation. If there are two things they should have done, one was include a printed version of the online PDF and the other would be to proof read the instructions as there are discrepancies.
