2 members (55shaker, Peggy M), 78 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1571396 02/27/2025 1:13 AM
So I finished up the wiring on my 36 gmc resto mod. 4.3 vortec, 12v system. I have a one wire alt. I got all done closed up the shop for the night and the next day the battery is dead frown So I pull the neg cable off and connect my test light between the neg post and the cable, The light glows. So I start disconnecting wires and the light will not go off. I go out to the alt and disconnect the wires there and the light goes off smile There are 3 wires there, one from the starter hot post, the alt post to the junction block, which then powers up the fuse box and the 3rd wire is power for the electric fan relay. If I touch the wire from the starter to the alt wire the light comes on. So I must not have this wired incorrectly. should that alt wire go to the ign switch or headlight switch first and then to to junction block? Not using the amp gauge, it's a volt gauge now. once I get this fixed I can start hanging sheet metal. Thanks for any help with this problem.
1936 GMC T-14 restro-mod
FAST55 #1571401 02/27/2025 1:47 AM
Maybe this will help
Not when Fast55 is using a one wire alternator.
FAST55 #1571420 02/27/2025 5:17 AM
Disconnect the big wire at the alternator output terminal and see if the light goes out. If it does, you've got a shorted diode bridge. Even a "new" alternator can have bad circuits. A parasitic drain in the regulator (the two small wires) usually takes several days to kill a fully charged battery. One faulty diode will still let the alternator charge, but the max output will be less than 1/3 of its rated capacity.
FAST55 #1571436 02/27/2025 3:12 PM
The only time the light comes on is when the wire from the starter and the alt are connected together. I can hold them in my hand and connect and disconnect and watch the light go off and on.
FAST55 #1571440 02/27/2025 3:32 PM
If I take the wire from the starter and run it to the run side of the ign switch would that fix this? Or the alt wire to the ign switch and then to the junction block, with a fuse by the junction block
FAST55 #1571461 02/27/2025 5:58 PM
Insomniac
Insomniac
Beware wiring the alternator to the ignition switch. You may find that you can't shut the engine off.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
FAST55 #1571594 03/01/2025 8:29 PM
I'm helping a buddy change the engine in his Dakota so the alt problem will have to wait a week or so before I get back to it. I'll update when I get back to it. Thanks for everybody's help so far.
