5 members (Otto Skorzeny, Barnfind49, Oldcaliforniakid, JW51, 1 invisible), 77 guests, and 1 robot.
Topics128,050
Posts1,055,671
#157122 02/04/2002 2:26 AM
Well, yesterday my #3 son called me from somewhere in Iowa. He started his own business repairing cars a few months ago and seems to be doing pretty well, at least he is 2 weeks behind. Anyway he had a 84 Chevy pu with a flat cam. The owner wanted an rv or something cam and Mitch didn't have a degree wheel. So, I thought that shouldn't be to hard and fired up the computer, got into a cheap cad program and set one up and printed it out. So far so good. Then I went out to the shop and looked around for something to put it on. I couldn't find any thick enough aluminum, but found some tempered masonite. I cut the masonite roughly on the bandsaw and glued the paper onto it. Then found some plexiglass to cover it with. Chucked it up in the lathe and turned it true. Cut the plexiglass with a hole saw to fit a 3/4" washer, and pinnned it to a 3/4" washer on on the backside of the masonite. Pinned the plexi to the masonite and was done. Then came the real test. I bolted it up to a short block I had setting on the engine stand. It works good and is even easier to see than the antique Offy one I've used for many years.
Dennis
#157123 02/06/2002 11:12 AM
So,,, when will you have your product on the market??? grin cool
necessity can be a mother,,,,,,,,of invention!
#157124 02/06/2002 5:03 PM
yea I was thinkin the same thing... I'd kinda want one.
May the force be with you - SoloWookie
solowookie.com
#157125 02/07/2002 12:02 AM
Hey guys,
I didn't plan on selling anything like this, but if you have something that can open a .cad or .dwg file I can send you the file to print out and you can make your own.
Dennis
#157126 02/07/2002 6:30 AM
But,,, but,,, you already have it mastered!!! grin
#157127 02/07/2002 6:50 AM
yea, ditto... LOL grin
solowookie.com
#157128 02/08/2002 2:31 AM
Yeah mastered,
I generally work like this, if I need something I'll build it or buy it but I only build one. Maybe that's why the CNC project for my mill is going so slowly, lack of interest. LOL
Dennis
Moderated by  MNSmith
