3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#1571205 02/25/2025 9:25 AM
Does anyone know how to stop oil from leaking out of those screws that hold the breather baffle inside the engine. I have a 235 and these screws are on the right lower bottom by the fuel pump.
I would use Permatex Seal Lock on the threads. Part # 57535
https://www.jbtools.com/permatex-57535-35-ml-seal-and-lock-thread-compound-1-26-fl-oz/
1950 Chevrolet 3100 (Ol' Roy)
I always used nylon washers.
Lead washers were used originally.
My Blog
If you unscrew them to seal will the baffle move?
1951 3100
Only do one at a time so it stays in place, unless you have the pan off.
My Blog
