| | | Forums66 Topics128,162 Posts1,057,047 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | Is anyone still selling the tie rod ends for the Second Series '55 Chevy 3600? | | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | Try www.rareparts.comI know they have kingpin sets and drag links and other steering parts. They'll also make new stuff for you if you send them your old stuff. Give them a call.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | Try www.rareparts.comI know they have kingpin sets and drag links and other steering parts. They'll also make new stuff for you if you send them your old stuff. Give them a call. I just checked them out. They look very helpful! Thanks! | | | | | Joined: Mar 2007 Posts: 3,444 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,444 |
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | How well do the repair kits work? | | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | I used the repair kit ends from Jim Carter, and also replaced the balls that the drag link connects to. On the tie rod, I used the modern style tie rod ends after removing the balls from the steering arms. It drives nicely, although I've only put 100 miles on it since, so can't comment on the longevity. I used the "weld-in" replacement balls but just pressed them in and peened the ends over as the originals were installed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 6,001 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,001 | mrcaddy, Otto's suggest source seems to be "out-of-stock" with most of the possible tie rod ends, both original style rebuildable and after market replacement style. Before we get too much more in the dirt on what parts are available, maybe let us know what you currently have on your truck? If you can attach a picture or two, we can better offer some sources for replacement parts. There are a lot of our usual vendors as well as some ebay sellers with NOS/NORS parts out there, but we need to know for sure what you have to lead you towards the best options or suggestions.  Oh yeah, I would recommend Jim Carter parts any time! I have used them quite a bit and can say I have never been unhappy with anything I have purchased from him. Also worth noting is his ME180TR Repair kit costs about 1/5th of Otto's suggest source for virtually the same kit.  PS - Since this thread topic is actually about steering it best fits in the Driveline forum, so it's been moved there for further conversation and help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Doesn't your 3600 have the tapered tie rod ends?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | Doesn't your 3600 have the tapered tie rod ends? Well, I've had this truck 40 years this summer and I'm not exactly sure. I know they should be stock and probably haven't ever been changed that I know of. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | My truck is a 1957 3/4 ton GMC Here is a reference link which may be helpful https://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.aspMy original tie rod had male ends, Threaded 750-16. I found replacement tie rod ends which were male, so bought some 1 inch cold rolled steel and had a new tie rod cut and threaded. New ends were ES150R and ES150L. Maybe you can find some with the same dimensions with female thread to work with your original tie rod. Good luck
1957 GMC 150
| | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | THIS is what I used. The studs on the joints are straight rather than tapered, which matches up with the hole in the 3100 steering arms after you remove the ball. They have 3/4-16 threads. One left hand and one right hand. Says they fit 1/2 ton and 3/4 ton up through 1959.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | When looking at the Moog photos and choosing a rod end pay attention to the length of the threaded shank, shorter gives you less range of adjustment when you have a jam nut (which takes up threads), you want as much insertion into the female threads as possible to aid in sleeping at night.
I found when I did mine a 1-1/2” threaded portion gave very little adjustment, maybe 3/16” of threads showing “at most” on each end, not much really….had to be more precise than I expected… didn’t leave much room to play with on fab’ing a drag link trying to get centered on the sector.
Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | |
