5 members (Rusty Heaps, Ridgeback, Phak1, Gdads51, moparguy), 408 guests, and 5 robots.
Topics128,162
Posts1,057,040
Members48,463
#1571137 02/24/2025 1:45 PM
Is anyone still selling the tie rod ends for the Second Series '55 Chevy 3600?
mrcaddy #1571139 02/24/2025 2:18 PM
Try www.rareparts.com
I know they have kingpin sets and drag links and other steering parts. They'll also make new stuff for you if you send them your old stuff. Give them a call.
1950 Chevrolet 3100 (Ol' Roy)
I just checked them out. They look very helpful! Thanks!
mrcaddy #1571145 02/24/2025 3:48 PM
Crusty Old Sarge
Crusty Old Sarge
Jim Carter lists a repair kit for 1/2 - 1 ton trucks.
https://oldchevytrucks.com/1955-195...d-end-repair-kits-replacement-balls.html
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1571152 02/24/2025 4:41 PM
How well do the repair kits work?
mrcaddy #1571157 02/24/2025 6:24 PM
I used the repair kit ends from Jim Carter, and also replaced the balls that the drag link connects to. On the tie rod, I used the modern style tie rod ends after removing the balls from the steering arms. It drives nicely, although I've only put 100 miles on it since, so can't comment on the longevity. I used the "weld-in" replacement balls but just pressed them in and peened the ends over as the originals were installed.
mrcaddy #1571167 02/24/2025 9:54 PM
mrcaddy, Otto's suggest source seems to be "out-of-stock" with most of the possible tie rod ends, both original style rebuildable and after market replacement style. Before we get too much more in the dirt on what parts are available, maybe let us know what you currently have on your truck? If you can attach a picture or two, we can better offer some sources for replacement parts. There are a lot of our usual vendors as well as some ebay sellers with NOS/NORS parts out there, but we need to know for sure what you have to lead you towards the best options or suggestions. wink
Oh yeah, I would recommend Jim Carter parts any time! I have used them quite a bit and can say I have never been unhappy with anything I have purchased from him. Also worth noting is his ME180TR Repair kit costs about 1/5th of Otto's suggest source for virtually the same kit. thumbs_up
PS - Since this thread topic is actually about steering it best fits in the Driveline forum, so it's been moved there for further conversation and help.
~ Dan
1951 Chevy 3 window 3100
mrcaddy #1571207 02/25/2025 12:39 PM
Doesn't your 3600 have the tapered tie rod ends?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #1571216 02/25/2025 3:15 PM
Well, I've had this truck 40 years this summer and I'm not exactly sure. I know they should be stock and probably haven't ever been changed that I know of.
mrcaddy #1571263 02/26/2025 12:00 AM
My truck is a 1957 3/4 ton GMC
Here is a reference link which may be helpful https://www.moog-suspension-parts.com/universal_outer_tie_rod_ends.asp
My original tie rod had male ends, Threaded 750-16.
I found replacement tie rod ends which were male, so bought some 1 inch cold rolled steel and had a new tie rod cut and threaded.
New ends were ES150R and ES150L. Maybe you can find some with the same dimensions with female thread to work with your original tie rod.
Good luck
1957 GMC 150
mrcaddy #1571268 02/26/2025 12:47 AM
THIS is what I used. The studs on the joints are straight rather than tapered, which matches up with the hole in the 3100 steering arms after you remove the ball. They have 3/4-16 threads. One left hand and one right hand. Says they fit 1/2 ton and 3/4 ton up through 1959.
mrcaddy #1571289 02/26/2025 4:21 AM
When looking at the Moog photos and choosing a rod end pay attention to the length of the threaded shank, shorter gives you less range of adjustment when you have a jam nut (which takes up threads), you want as much insertion into the female threads as possible to aid in sleeping at night.
I found when I did mine a 1-1/2” threaded portion gave very little adjustment, maybe 3/16” of threads showing “at most” on each end, not much really….had to be more precise than I expected… didn’t leave much room to play with on fab’ing a drag link trying to get centered on the sector.
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
