5 members (Roxxstar, ronsway, Frank50, Danielbolt, 1 invisible), 314 guests, and 5 robots.
Topics128,156
Posts1,057,020
Members48,460
Today's Recalls
Northern Tool & Equipment Has Recalled Air Compressors
Reason: The capacitors on these compressors can overheat.
Distribution: Nationwide.
http://www.safetyalerts.com/recall/p/02/p001176.htm
<a HREF="http://www.safetyalerts.com/recall/p/02/p001176.htm">
Read Article</a>
Chargetek Has Recalled Battery Chargers
Reason: A manufacturing defect inside the charger can cause
overheating of internal connections or external wiring, presenting a fire hazard.
http://www.safetyalerts.com/recall/p/02/p001178.htm
<a HREF="http://www.safetyalerts.com/recall/p/02/p001178.htm">
Read Article</a>
End Recalls
good eye!! keep us informed. stuff like this is what causes fires in the barn--and we can't have that!!!! cool
Moderated by  MNSmith
