| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | I was told a long time ago that 30wt motor oil could be mixed with gasoline for use in 2 cycle engines. Is this true? Was it true in the past when 2 cycle engines were "less sophisticated?"
Just wondering because I never seem to have the 2 cycle oil when I need it but always have lots of different motor oils handy.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | The old outboards from the 50;s as well as chainsaws used 30 wt oil but the newer 2 cycle oil is way better and for what it takes to buy a gallon and put it on the shelf I would not use 30 wt .
Last edited by KEVINSKI; 02/16/2025 7:19 PM. Reason: Did not show up on thread title
| | | | | Joined: Feb 2004 Posts: 29,785 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | One of the most expensive mistakes I made was running one can of "generic" 2 cycle oil in an Echo chain saw- - - - -locked up the engine before I used one tank of gas. That one cost me a new crankshaft, and an oversized piston. I was able to save the cylinder, but it had to be honed out to fit the bigger piston. Jerry
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Yes, there are 2 cycle oils for air cooled engines like chainsaws which are somehow different than the oil used in water cooled outboards.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,785 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | I've got a 1949 Scott-Atwater 7 1/2 HP outboard stashed away in the barn. The fuel/oil mix instructions are "1/2 pint SAE 30 non detergent motor oil to 1 gallon of gasoline"! When I would go fishing with that one, the skeeters on the lake didn't stand a chance of surviving! It's got two threaded bungs under the cowling for spare spark plugs. They fouled out pretty frequently.
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Unless you're using a fair amount you might want to buy can of premixed fuel. You can find saw manufacturer branded or generic . Local farm store should have a good selection.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | My 1955 Johnson 10hp has instructions on the cowl for a sale 30 mixture but I have always used a outboard oil at about 40 to one mix and it has been good had this one from my teens. | | |
