Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (carbking, Shade Baby), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
I pulled the clutch today and found this beauty.
Super beat flywheel, wrong size friction, and scorched pressure plate...
This is fine.
Getting the clutch and pressure plate out with the bellhousing on was a huge pain. Getting everything twisted to clear the crossmember was something of a mess.
Are you supposed to pull the bellhousing first? Looking at the engine, I am not sure how to support it without the bellhousing attached.
Suggestions?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
H Online: Content
It's impossible to pull the bell housing without removing the flywheel- - - - -bolts hidden underneath it. If you think you must pull the bell for some reason, put a long 4 X 4 across the fenders near the cowl, and use a 2" wide ratchet strap under the oil pan to support the back of the engine.
When I bought the truck, the dude said he put a new clutch in the year before. When I got it home, the clutch was totally out of adjustment so it did not fully disengage when you pushed the pedal.
I now suspect that he did replace it, did not adjust it, and drove it long enough to ruin all of the pieces before I got it and adjusted it right.
It should be real interesting to see how it drives with a good flywheel/clutch pack.
@Jerry: I am confused. I am working on a 283, not one of the sixes. As far as I can tell, all of the bolts holding the bellhousing on come in from the outside/back.
I don't have a pic of mine, but this one from Lugnutz is similar and also seems to have all the bolts on the outside?
Bellhousing
Was the disc in the right way? If the disc is in the wrong way it won't disengage all the way. One tell tale sign it was in backwards is the fly wheel bolts will have some scratch marks on them.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
yep, you have to support the engine and take the BH off.
Disc/PP look like it was installed incorrectly with the shape of that FW. Can that be machined?
Like with that, I`d have to reinspect everything the PO touched.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
The clutch disc was in correctly *this time*, but the reused flywheel bolts indicate that it was installed wrong previously.
This flywheel is pretty badly beat and the machine shop wants more to resurface it than a new Luk costs. Given the obvious hot spot damage to the pressure plate, I am not sure this flywheel is salvageable anyway.
So the project is on partial hold until I get a new flywheel.
H Online: Content
OOPS! I missed the V8 detail! Same procedure, however- - - -jack the engine up under the oil pan (use a piece of 2X6 between the jack and the pan to avoid denting it) and unbolt the rear mounts. Then support the back of the engine with a strap if you need to move the truck around while the bellhousing is off. There's really enough room to remove the flywheel for machining without pulling the BH- - - -most shops I've worked for would fire me if I tried something like pulling parts for no good reason. That's about a 3-hour job in a flat rate shop- - - -drop the clutch, pressure plate, and flywheel, resurface the flywheel, and test-drive the rig to lunch with a new clutch installed. Once the flywheel is refaced, you might get away with reinstalling those new-looking clutch parts.
Too bad we're not closer to each other- - - -I've got half a dozen of those flywheels stashed away!
To be clear, I did take the whole assembly out without taking the flywheel off. It just seemed like it didn't want to fit through the bellhousing/crossmember slot as installed.
The clutch parts are also roached. The clutch is badly glazed and is no longer flat. The pressure plate has visible heat spotting, a few cracks, and a few chunks where it galled and left pits.
All three of these are getting replaced.
A flywheel from HRL would be your best bet, especially if its ready to go.
Yeah those bolts look toasted and about to break.
Id give that pilot bushing a check too.
~ BD.
Just replace the pilot bushing.
BC
1960 C60 pasture art
I have new:
Flywheel (on the way)
Flywheel bolts
Pilot bushing
Clutch disc
Pressure plate
Clutch bolts
Throwout bearing
Clutch fork clip
Bellhousing mounts
Once all of that goes in, it should be a pretty good setup.
I am going to the 60s/70s flywheel without the machined lip around the edge so I can use the more common 11"/12" clutch disks
Heck Yeah!! I used blue lock tight on the FWB. Torque wrench.
I know you know all that stuff. Thatll be a nice setup.
~ BD.
When you get your flywheel mounting bolts make sure that they are the same LENGTH as the old ones. If you don't check this it can cause a lot of headaches. Don't ask me how I know just know I know and keep on working. 2 minutes of inspection will save you a lot of REWORK.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Thanks. I got a new set of SBC bolts, but my wife and I are taking turns in the hospital so it has just been sitting ever since.
