2 members (Otto Skorzeny, TexasA&M48Truck), 144 guests, and 3 robots.
Topics128,095
Posts1,056,480
Members48,444
Good morning friends and neighbors :-) I put power steering in my 55 second series truck and I am looking for some information on setting the drag link to pitman arm for proper adjustment. I think I have more turning to the left than to the right. Any help and advice would be greatly appreciated. Thanks
1955 second series 3200
steering box needs to be calibrated. Center it and put the steering shaft in. Pull steering wheel and center it.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Thank you for that info, I understand the objective do you know a source that gives details on the process.
Mine was in the CVF power steering box instructions. centering the box is crucial. Thats your L+R travel.
Someone can describe it better than I.
~ BD.
Thank you
What I did when I found that my travel L+R was not the same with my column in was,
I pulled the column shaft out of the box and centered the box . Turn all the way to one side then count revolutions
to the other side. Then 1/2 of that back the other way is center. reinstalled my column shaft and pulled the steering wheel and centered it.
~ BD.
