0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 200 nothing beats a try but a failure | | nothing beats a try but a failure Joined: Feb 2019 Posts: 200 | After the two coats of satin black single stage and two coats of satin clear had cured for several days I ran my hand across the roof. The finish had micro scuff marks from my hand. It looks like felt when you brushed in one direction. It will not come out. What on earth have I done? Any Idea's? | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I had a similar situation about five years ago with base coat/clear coat. I had sprayed the vehicle in September in 65°dry weather, required for spraying but then we had a cool spell. For the next week, I’d park it in the garage then take it back out in the day so the sun could help cure it. I buffed it out after two weeks and it looked fabulous but you could dent/scratch it with your nails. I let the vehicle sit in the garage over the winter until the spring when it warmed up and let it sit in the sun. A few days under the sun in 70° weather, it finally hardened.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | 87GN, what was the sequence of painting, was the roof last to get sprayed or first? It sounds like possibly there was dry overspray laying on the roof from painting the rest of the truck first, or overspray on the fresh roof paint from spraying it first and the rest of the truck next.
| | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | The paint I used says it takes 7 days to fully cure. I would wait and see if it hardens up, then possibly respray the clear, and DON'T TOUCH IT for quite a while. Check the Tech sheet for your paint and see what it says. Cold weather extends cure time quite a bit. I think that most tech info specifies curing at 70F and 50% humidity. I'll bet you're a bit cooler than that.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | When you spray in cooler weather you need to check the actual surface temperature’s of the vehicle. The surrounding air might be sufficient for spraying, but if the vehicle has been sitting in a cool or cold garage, it will take some time to get the body to spraying temperature. If the surface temp is low, it will extend the drying time sufficiently.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2019 Posts: 200 nothing beats a try but a failure | | nothing beats a try but a failure Joined: Feb 2019 Posts: 200 | How can I apply new satin clear on existing clear? I know scuffing will be involved. But will it stick? | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | If the current clear is cured but fuzzy, I would wet sand it with 400 - 600, not just a scuff pad. The total sanding will promote adhesion.
