5 members (TUTS 59, ‘37ChevyPU, 2-Ton, Forty9, Stovebolt48), 57 guests, and 5 robots.
Topics128,203
Posts1,057,412
Members48,471
U
U Online: Content
I replace the three brake line junction blocks on the rear. One on top of the axle and the two that connect to the wheel cylinders. Does anyone know if the blocks up front are still available? One by the front right brake and one on the left side under the passenger.
~ John in Utah
Here We Go
Follow in his DITY Bay
Have you tried Jim Carter?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
If you have 1/4" lines, Jim Carter has them, Brake Line Division Block, part # MEE249, $21.95.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
U
U Online: Content
Jim Carter has the two different ones for the rear, which I already have. I'm looking for the ones up front. But, I'll look again. Sometimes I don't see things on Jim Carter until someone gives my a part# - I don't know why.
~ John in Utah
Here We Go
Do you have the original blocks?
This company might be able to help you if Jim Carter doesn't pan out.
Specializing in antique, vintage, classic, obsolete, unique and hard-to-find brake parts, bonding, riveting, rebuilding, drum and rotor machining, custom made brake hoses
Brake Materials & Parts Inc
800 Sherman Boulevard,
Fort Wayne, IN 46808
260-426-3331
http://www.brakematerialsandparts.webs.com/
1950 Chevrolet 3100 (Ol' Roy)
It’s been a few years ago, but I found them at a local NAPA store. Might be worth checking one near you. They might even be able to order them from their regional warehouse?
U
U Online: Content
I do have my old ones. They were brown until I used the wire wheel. I'm just thinking since I'm building from scratch maybe I can replace them with new while I have easy access. Thanks for the ideas guys!
~ John in Utah
Here We Go
I would use the old ones ,you never know what they change up on new parts .not to say they will be any difference but I found a lot of the new stuff had slight differences.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I reused my old ones and had no leakage issues.
U
U Online: Content
Maybe I'm being a worrywart. The outside of the blocks cleaned up well and I tried to clean the connection area as well. I guess if they don't leak I shouldn't worry about it. Thanks for everyone's input.
~ John in Utah
Here We Go
I used the old division blocks on my brakes also, and didn't have any leaks. They were the only parts of the brake hydraulic system that I reused.
All of the blocks on my truck are 75 years old and they don't leak. I don't think they've ever been off the truck, either.
U
U Online: Content
Fingers crossed. It will be a little while before I actually bleed the brake system, but I'll be sure to post an update.
~ John in Utah
Here We Go
