9 members (MickeyP, papas52, Biermann, Otto Skorzeny, Donf, jmoore, Shade Baby, TS3600, BC59), 118 guests, and 2 robots.
Topics128,162
Posts1,056,949
Members48,458
FMM
Offline
I can't see to locate any posts about the torque value for this 235 1960 model I'm getting checked over to go in my 48 COE. Also head bolt torque and tappet clearance. I'm sure it's been posted many times before but I can't find anything. Thanks
From a 55.2 service manual (should be the same as your 60 engine)
Rods 35-45 ft lb with oiled threads
Mains 90-95 ft lb
Head 90-95 ft lb Tighten in steps in a circular pattern
Intake valves 0.006 hot
Exhaust valves 0.016 hot
FMM
Offline
That's what I needed, thanks so much.
If you use anti seize compound instead of 30 weight motor oil on the threads, reduce the torque spec by 10%.
Just an added note that the 1959 Chevy Truck Shop Manual Supplement shows two changes to Kevin's info.
Mains 100-110 ft lb
Exhaust valves .018 hot
There is a 1960 Chevy Truck Shop Manual, but I don't have a copy nor could I find anything in our online sources. The 1961 Chevy Truck Shop Manual Supplement says follow the specs in the 1960 manual.
~ Dan
1951 Chevy 3 window 3100
