7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf), 74 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#1569383 02/01/2025 10:09 AM
Is there a fuse beteeen the key switch and the solenoid on the starter
1972 5500
Svcattle #1569385 02/01/2025 12:07 PM
7
7 Offline
Normally no fuse or fusible link in that circuit, is the wiring original?
Yes the wiring is original. Ended up replacing the ignition switch and starting circuit works perfectly again . Thanks
Svcattle #1569670 02/04/2025 6:29 PM
H Online: Content
It's not original, but it's a good idea to put a fusible link between the battery cable terminal at the starter and the wire going from there to the ammeter. It's a short piece of fuse wire that melts in case of a heavy current short circuit. They're available in the "Help" section at most local parts stores.
www.ebay.com/itm/156268452533?
Svcattle #1569674 02/04/2025 7:58 PM
Be careful about selecting a fusible link. It should be a smaller gauge (higher number) than the wire it serves. For instance that 10 ga fusible link that Jerry linked to would be used on a 6 gauge harness wire. If you use a fusible link that's the same gauge as the wire you're connecting to, it won't protect that wire. You want the fusible link to melt before the rest of the wire does. Fusible links also have insulation that will contain the melted wire and not go up in flames.
Svcattle #1569801 02/06/2025 4:08 AM
Just ask the owner of any '70s Dodge van :-D
One of my buddies had one of them back in the day, and all those fuse link wires were always failing.
Tronman #1569811 02/06/2025 3:04 PM
Failing, or just doing their job?
