7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | I have the opportunity to purchase a 1953 3100, I'm looking to swap out the rear end along with the transmission and driveshaft if the deal goes thru. I have a limited amount of intelligence and alot of mechanical experience, can anybody and everybody guide me, better yet, in layman terms tell me what parts I would need to make this happen. I would like to switch over to parts that are readily available and easily repaired. Can I go with a rear end that has disc brakes already and still work with existing emergency brake setup? These are the questions among others that I would need information and installing procedures. Thanks Jim
1950 chevy shortbed 3100, 216 with a 3 on the tree.
| | | | | Joined: Oct 2021 Posts: 6,921 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,921 | There's no "bolt in" swap. What vehicle with rear discs are you considering? I doubt any rear disc brake setup on a modern car will work with a 53 truck parking brake setup.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | In my opinion, you will first need to select what transmission you want to go with. Then choose an appropriate rear axle gear ratio which will work well with that transmission. My first choice would be a T-5. They come in a number of gear ratios 1 through 5. Fifth gear ratio is the one that will best determine what rear axle ratio that you want to look for so that overdrive is useful and first gear isn't granny gear. Parking brake cable attachment will need some fabrication if you go with a modern rear axle.
| | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | I'm not sure what rear end to use or where to find one that will work, everything I'm reading the width is like 62 inches and new shock pads need to be welded on, if that's correct. As far as the transmission goes I'd like to keep the 3 on the tree linkage but would need a newer version transmission that would work for the 3 on a tree. I can honestly say the e brake is really not a major concern as the floor boards are rotted out and I can do like Fred Flintstone to stop it only kidding. Any reccomendations on what rear end and transmission that would work would be helpful.
| | | | | Joined: May 2004 Posts: 76 'Bolter | | 'Bolter Joined: May 2004 Posts: 76 | Consider the differential swap. This would be the easiest way to success with. You will keep the brake lines and emergency brakes as they are. No mods. You will not get disc brakes but the diff will be 3.90. You will have to mod the axle perches as the pivots will not work. As 52carl noted, the T5 is best option and closest to bolt in you will get with minimal modifications. They are getting hard to find used but new and rebuilt’s are available. This is the route I went with no regrets. | | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | Thanks, do you have rear end information and t 5 information, I looked at t 5 on line and they are going for about $2400.00, I'm looking for plain Jane daily driver trans.
| | | | | Joined: Feb 2004 Posts: 29,848 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,848 | You don't have to buy T5s a dozen at a time! Local salvage yards in my area are getting $500.00 to $750.00 for T5s, and private sales on places like Facebook marketplace are even lower. Jerry
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Definitely search your local Craigslist and FB Marketplace ads. There was an S10 T5 with what most would say were great gear ratios and mechanical speedometer drive on the East Coast that was advertised at $350. They are out there, you just have to actively look and watch.  You could also put an ad of your own in the Truck Parts Wanted forum.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Thanks, do you have rear end information and t 5 information, I looked at t 5 on line and they are going for about $2400.00, I'm looking for plain Jane daily driver trans. Fellow Cheapskate here…. Even though I already own a very rebuildable core S10 T5, this (see link below) is a pretty good deal. If I wasn’t such a cheapskate, I’d jump on it. A cable speedo S10 T5 core will be hard to find for less than $500. And if you bought one for that, the rebuild kit would cost you another $150 (low side). Not mine. Not super far away from me, however. https://www.facebook.com/share/15nnDWjMMs/?mibextid=wwXIfr
1951 3100
| | | | | Joined: Jul 2000 Posts: 2,200 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,200 | I'm looking for plain Jane daily driver trans. Is the truck really going to be a daily driver? Or is it just an occasional use hobby vehicle?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I think the original question was in regard to rear end swap. Does this truck have the original torque tube setup? I assume so?
The 55-64 1/2 ton truck rear is still super common and you can find one for less than $100, probably closer to free. It is a super easy swap. Might need someone to weld on some spring perches for you…that’s about it.
The rear under my truck is one of these that was literally free. I found out, during install, mine had a 3.38 gear set in it. 99% of them are going to be 3.90. 3.90 with 30 inch tires is a very highway drive-able combo.
1951 3100
| | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | So years 1955 64 half ton rears will work, with the exception of welding perches on? Correct me if I'm wrong any 55 64 half ton trucks, or a specific model.
| | | | | Joined: Jan 2023 Posts: 118 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 118 | Can you be more specific on which t 5 to get? Year range Model or casting number etc.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | There’s some overlap in the 63ish-64 range with the 6 lug 12 bolt rear end. The one I’m referring to is called a 55T or HO33. Looks nearly identical to the torque tube rears. Just has a normal u joint on the front.
1951 3100
