5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
I am going to disc front brakes three of the bolts holding the backing plate on came off easy the fourth in the lower front will not move the nut is off any ideas. Already tried lots of pb blaster and hammer I do not have a torch. Thanks
I would go down to your local hardware and buy a propane torch. It would work fine for heating the area to break that bolt free.
From your description, I assume it's rusted into the hole thru the spindle. A little bit of heat around the hole will help release it - it doesn't need to get red hot. If you can access the head of the bolt with a socket, use a breaker bar and start working it back and forth. Avoid hammering on the threaded end of the bolt or you'll mushroom it and you'll then need to cut the mushroomed end off. The largest hammer you can find is the best thing to use. Hitting it with dinky hammer is more likely to damage things.
Heat, PB, hammer, and repeat as necessary. It'll eventually come out.
7
7 Offline
Heat is magic, you can also get a MAPP gas hand torch which will heat it faster than propane.
Crusing in the Passing Lane
MAPP gas comes in Yellow cylinders.
Ed
They say MAPP gas can't be used in some propane torches, but I've done that and haven't blown up. grin
Ok thanks for the help
7
7 Offline
I think the MAPP torch tip can better withstand the higher heat than the propane tip. I know when I used a TurboTorch with acetylene it didn't like being throttled down, the tip would be bright red unless you turned the torch up all the way, it has to pull in enough air to help cool the tip. I think the MAPP tips are designed to do that.
Got it out thanks again for the help
