3 members (cmayna, HandyAndy, 55shaker), 78 guests, and 3 robots.
Topics128,148
Posts1,056,810
Members48,454
#1568843 01/25/2025 7:04 PM
Greetings fellow Stovebolters,
I have a '58 Apache Fleetstide, 1/2 ton with original steering gear. How difficult is the rebuild on these? Wondering if I should mess with it or buy a replacement unit from Classic Industries.
I welcome your thoughts.
If it's a manual steering box, it's not hard to rebuild. You'll need a fish scale to do the bearing preload and sector adjustment. That's covered in a Service Manual.
Depends on how much Classic wants for a replacement, and what you think your time is worth. If it's a power steering box, then I'd probably go with a professional rebuild.
O Online: Content
Or send it to Lares for a rebuild. They did my '76 F-150 8 or 9 yeaqrs ago. Excellent job.
www.larescorp.com
1950 Chevrolet 3100 (Ol' Roy)
I do not see one listed on the Classic Industries site.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Thank you for the replies. I never knew about Lares. Question, can I remove the steering gear box without removing the steering wheel and shaft?
Not really, no. The steering shaft is pressed in to the steering box and it is intended to be treated as a single unit from there.
If you could separate them, you would still have to remove the column from the truck to put them back together and reinstall them as a unit.
The FAM says to lift the cab to get the column out, but I have seen a couple people say it will come out the bottom if you lift the frame about 2.5'. I have not tried it, so I can't confirm that though.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I took the steering column with the box attached out of the bottom of my '57 GMC 1/2 ton V8 while the truck was on a lift. And put it back in. And it still worked !!
Really, lift the cab?! Wow. I do have a lift so, I was figuring on taking the steering wheel and turn signal off and pulling it out the bottom. I suppose that would work. Appreciate the tip on the units being pressed together. Answers my question. Another question comes to mind, can you rebuild the box on the frame or is it better to remove the whole assembly? I assume the later.
Sorry about the repeat post. I was getting an error pop up, now I cant figure out how to delete the duplicates.
No worries, I'll delete the duplicates for you. I believe you can do that by clicking on the edit button on the lower right. Should work for your posts but not other members. Moderators have that ability on all posts.
[on edit] I believe that an AD steering box could be rebuilt in-frame, but the rub might be taking the steering shaft out the bottom (something is guaranteed to be in the way with the box bolted to the frame. Not sure if that would apply to a '58. But if you could do it in-frame, it would likely be MUCH harder than just removing the assembly.
You can run the front of truck up on ramps to remove the column.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Thanks guys.
It appears Lares has gone wholesale as they now direct you where to go to buy their products. Lots of parts stores listed
1956 3100 three speed 6 cyl. Stock with a few upgrades.
