0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1568508 01/21/2025 3:09 PM
I just acquired a 1954 GMC 450 fire truck minus cab and front end. 302 eng. and 5 speed trans. with an electric 2 speed rear axle. My question is was electric 2 speeds available in 54 or was this axle swapped in at some point?
7
7 Offline
If it is an older axle it is an Eaton brand, GM corporate axles were vacuum. It wouldn't surprise me that a GMC/fire truck would have the Eaton. My 1957 Chevrolet shop manual has tear-down for both. I checked the 1954 Chevrolet Truck specs on the GM heritage site, they list only one 2 speed axle, it being a vacuum shift, that doesn't mean that GMC didn't use the Eaton.
John L. #1568563 01/21/2025 10:52 PM
Most of the 2 speed axles have two ratios- - - -"Slow"- - - -and "Really slow!" Chances are that the coach builder that made the fire body swapped in a 2 speed to get the rig moving when it had a tank full of water onboard.
The parts book shows two electric shift rear axles. Eaton 16600 6.50 & 9.04-1 and 5.57 & 7.75-1.
Crusing in the Passing Lane
I swapped in from a 6.5 single to a 5 something(I never counted the teeth) high two speed in my ‘54 630 with a 503. Milled the head .092”, has adequate power at 5200’ elevation.
Ed
7
7 Offline
I thought I struck gold when I was able to remove the single speed 7.20 :1 and installed the 6.40/8.70 or whatever the ratios are. It changed my road speed by 10 mph in high range. Not that I expected highway speeds but I can now keep from upsetting folks on the 55 mph two lane, it'll do about 62 mph wound out at 4000 rpm.
Big Bolt Forum Co-moderator
78buckshot, what is that 6.40/8.70 rear axle out of?
1948 Chevy 2-Ton
Super55 #1568803 01/25/2025 12:59 AM
7
7 Offline
The 2 speed pig came out of a 1956 Chevrolet 2 ton, one of our Big Bolt members, DougH6100 offered it to me. We live about 30 miles from each other so it was a "no brainer". I measured my axle housing and bolt pattern, measured the doner truck axle, looked like a fit. I had to use the axle shafts from the doner truck due to the length difference but it all was a "bolt in" process. I also salvaged the 2 speed shift valve and knob/cable from the doner truck, it fit like a glove. I ended up making gaskets for the pig and rear cover, I couldn't find any 13 bolt gaskets, I also rebuilt the vacuum actuator that mounts on the pig. I plumbed it with 3/8" soft copper 'cuz I have a good stock of it left over from my HVAC career. The 2 speed works great.
In my admittedly limited experience with 2 speed axles, I've found that a vacuum shift unit is a lot smoother shifting than an electric type. Having a good sized reservoir tank with a check valve in it is a necessity, because when a shift is needed on an uphill pull, the intake manifold vacuum is going to be pretty close to zero.
Reproduction GM axle vacuum shift diaphrams are also available. On ebay, at least the ones that use Bendix part number 374451
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
7
7 Offline
I've driven trucks with electric shift and trucks with vacuum shift, there is a learning curve to both. Once you have some miles on either one it becomes second nature, just like learning the little quirks of each transmission. I added a reservoir to the vacuum system when I added the 2 speed pig, the original vacuum system on these trucks has a check valve already installed on the firewall, that valve is the first fitting in line from the manifold. If you install a check valve at the reservoir, it won't allow vacuum into the tank or won't allow vacuum out of the tank depending on the orientation of the valve, the factory check valve holds whatever vacuum is in the system and keeps it from being pulled back into the manifold.
Your 450 would either have a 16600 or 1700 Eaton. They were very good rears and Eaton built them for many years. Parts are still available. All truck manufacturers that offered a two speed used them. I always found more Eaton parts at Ford dealers than anywhere else. International dealers also stocked a lot of parts for them. Even while they were offered, GMC didn't stock many parts for Eaton rears. The main thing that goes wrong with them is the shift box. There is a pair of limiting switches that corrode over and there is a small ball bearing that corrodes if water gets in the box. But these parts are still readily available. Here is a parts catalogue
Can you provide a link to the part? I looked for it and couldn't find it.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
