1 members (Jimmie D), 110 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
Page 2 of 2 1 2
FMM
Offline
Here is the numbers/letters by the starter on this purchased 235 motor..
If you follow the fairly known engine casting date code info, the following should indicate your engine info:
CON4 = Conveyor line # 4
A = January
8 = 8th Day of January
0 = 1960 (Model Year)
This should confirm you have a base level 1960 235 out of Chevy C-10 thru 30 combined with the other info you have provided.
~ Dan
1951 Chevy 3 window 3100
There should be some other numbers on the block as well as the head .From them just punch up casting numbers 235 and it should tell you the year and application of the motor .There is also a machined pad next to the distributer that has small numbers stamped on there and from them the US motors have were they were built and other imfo .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Again; blue paint. If it’s original, points toward a car engine with hydraulic lifters which is great as long as they are working right.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Page 2 of 2 1 2
