9 members (Gdads51, Shaffer's1950, 78buckshot, Phak1, Leo, dt235sd, Jon G, mick53, 4tttt8),
87
Mod | | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11 'Bolter | | 'Bolter Joined: May 2015 Posts: 11 | I have a 52 3/4 ton and want to swap out the huck rear brakes. There was a tech tip called the need for speed where it said you could swap the rear brake setup from a (73-2006) fourteen bolt rear axle. Is this a direct swap? Any help would be appreciated. Thanks | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The short answer is, no it's not a direct swap. In the 1-ton forum, if I recall correctly, Grigg has a long thread about swapping a 14-bolt axle in place of an HO52/72 Eaton. In one of the discussions the question comes up about swapping the HO series brakes for the 14-bolt brakes, both Bendix. You have to really know the parts interchangability. There is a particular combination of backing plate, hub and shoe and drum that works. It's involved enough that I'm willing to wait till the Huck drums get too thin to use before I go down that path. Right now my issue is front drums. If I could find Bendix brakes from a 52 or later I'd do that immediately. Huck brakes work fine if they are in good shape, and despite comments to the contrary, they do have servo action, just not as effective as the Bendix units. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: May 2015 Posts: 11 'Bolter | | 'Bolter Joined: May 2015 Posts: 11 | Ok thanks. I am going to disc on the front and was hoping I could just upgrade the rear. | | | | | Joined: Nov 2021 Posts: 1,403 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,403 | I did the 14 bolt swap in my 1950 3600 and while I have not driven it yet (long story) it went fairly well. The biggest issues were the machining of the spacers and the cost to replace the drums. The 14 bolt I installed came from a 1986 C3500. | | | | | Joined: May 2015 Posts: 11 'Bolter | | 'Bolter Joined: May 2015 Posts: 11 | | | |
