4 members (Hotrod Lincoln, Guitplayer, LAROKE, 1 invisible), 54 guests, and 3 robots.
Topics128,154
Posts1,056,840
Members48,456
H Guys, Can anyone tell me if there is a bushing available for the arm shaft that the clutch pedal linkage connects to? The hole where my clutch linkage attaches to the arm shaft is wallowed out quite a bit. So much that the clutch pedal will move 1/2 to 3/4 inch before it pushes on the link. Kind of hard to adjust pedal free play when I have this much slop in the system. I attached a picture I copied from Jim Carter trucks that shows the link and the arm shaft.
Deegs
1953 3100
Mine was badly worn also so I built it back up with weld metal. It seems to work reasonably well. The pedal return spring should keep the linkage slop-free so I wouldn't think that would be an issue. Your adjustment should close any gaps in the linkage.
Deegs - As a possible alternative, something like THIS might be a solution. You can also find similar brass bushing at most hardware stores.
~ Dan
1951 Chevy 3 window 3100
Kevi/Dan,
Thanks for the info. I thought taking it apart and welding the hole would be my only option but then I started looking for bushings. None will fit perfect since it is oblong, but anything would be better than what I currently have. Going to check the local hardware store. They were extremely effective in supplying all the stainless hardware I needed to put the truck back together.
Deegs
1953 3100
