5 members (Goach2, 50Chevy3100, Shade Baby, Cosmo, 1 invisible), 64 guests, and 2 robots.
Topics128,179
Posts1,057,133
Members48,463
I've seen a pictures of stands that people have made to put their cabs on that have wheels. I'm wondering if anybody has measurements, or plans for something like this?
I'm sure I can figure something out, but I figure why reinvent the wheel if I don't need to?
May the force be with you - SoloWookie
solowookie.com
http://www.stovebolt.com/truck/cabdolly.htm
Try this one, says he has plans if you email him.
You might ask on the lounge, I've seen others too, but cann't ask the right wording for "search"
Wook, I got infor from good looking company if they are still around. It's been awhile. I had an address for on web with good pix and stuff, thinking it's same guys, can't figure it out now. Try Bradley Machine and Welding
118 Water Street
Johnson City, TN 37601
615-926-5042
They make one called the "bottoms up" lift.
They had plans or kits. Some fellas say to bolt a rig in the door hinge pockets and the door latch area, extend across door and bolt pivots to that. That way you can access all areas and it won't be in your way.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
thanks for the info guys...
solowookie.com
Stick the cab on a 2 wheel, small flatbed trailer.
actually instead of purchasing a truck I went with a bed just like you are talking, although a bit larger... its 10'x6' with a ramp tail gate. much easier to load and unload then a truck.
solowookie.com
It isn't rocket science. I've made two roller stands for my '39 cab and now my '49 cab (it just rolls around the shop floor). It's not real hard if you just apply a little common sense -- measure the width of the frame (where the cab mounts). Set two 2x4's or 2x6's on the shop floor set at the same widths, put stringers between 'em. Put casters on the bottom and carpet strips along the top and you're done.
I got a little fancy with my last one -- put double stringers (like a pallet) so I could lift the whole thing with the forklift (forks on the skidsteer).
You're only limited by your own creativity and common sense.
Good luck!
~ One of many.
thanks John...
yea I think this is a part I can handle alright... my fathers a carpenter, but I didn't learn near as much from his as I wanted too. I was always busy running his ranch was he was working... I've still picked up quite a bit a long the way.
solowookie.com
My first post was about a body rotiserrie stand not a roller type, I misunderstood! frown I have used 2x10's or 2x12's on edge made into a box, much like a sandbox about 4ft square and ran a 2x6 across ends to mount swivel casters on (4" or bigger) and set the cab on it. Nice and higher too. I made sure the wood hit cab where the front mounts bolted on frame and about anywhere on back floor area. I have also used the upper frame from my COE frames to make similar roll around for them by removing from main frame and bolting to the above rack. Then it uses the orig mounts for cab. Your dad may have some 4ft lumber laying around to make this. Just use 16d nails ot lag bolts in corners, Nothing fancy. Also you can buy those wood and carpet made up racks at some of the Import tool stores for cheaper than the casters will cost probly and just add lumber to it to fit cab. wink
G.L. Grumpy's
Old Iron Ranch
Moderated by  MNSmith
