6 members (50 Black, greenie-reddy, 60steve, 52Carl, GradyB, cmayna), 133 guests, and 5 robots.
Topics128,204
Posts1,057,294
Members48,467
U
U Offline
Starting to work on my lever action shocks and they use 1/2inch x 18tpi bolts. Searching the internet today and I can find 1/2inch x 13tpi or 20tpi bolts, but no 1/2inch x 18tpi bolts. Anyone have a source?
~ John in Utah
Here We Go
Follow in his DITY Bay
What do those 1/2-18 bolts screw into. If they're screwing into the body of the shock absorber, then they're probably specialty bolts or plugs. If they're just attaching the shocks together with a nut on them, just use standard 1/2" bolts, either 13 tpi or 20 tpi.
Are you SURE they're 18 tpi? Did you use a thread pitch gauge? Not disputing you, but I'm not seeing anything except 13 tpi or 20 tpi 1/2 inch bolts in the 1929-1954 parts listing.
U
U Offline
The rear shocks have threaded holes and I did measure the threads with a pitch gauge. I was able to pick up a few bolts from a local bolt vendor, but he didn't have the short bolts (1 1/2"). I'm going back tomorrow to see if he has the same bolts I got today, but threaded all the way down. Then maybe I can cut them off. Otherwise, I might need to drill the holes out and use different bolts with nuts and lock washers?
Actually, the shocks have smooth holes through them, but this spacer plate has the threads to hold the shock to the frame.
~ John in Utah
Here We Go
Moderator
Moderator
2 Offline
Are you sure it's not a 9/16-18 thread? There is not much difference in the diameter and if you used a tape measure on a rusted bolt, it would measure about 1/2 dia.
Just my thought as I looked in my 1940, seventh edition of the machinist handbook.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Why not just run the long bolts through a die and thread them all the way and then cut them to length?
1950 Chevrolet 3100 (Ol' Roy)
On my 41, they are 9/16-18
U
U Offline
This is why I keep you guys around! You guys are AWESOME!
Don, You were correct about the rusted bolt measuring around 1/2". I went back to the bolt store this morning and another guy helped me. He said the bolts were 9/16"-18. I took a couple bolts in yesterday and I asked for 1/2", but they actually gave me 9/16". I should have looked at the receipt I guess. Also, this morning they found me a bolt that I could cut down to the length I need. Life is good.
Thanks again for everyone's suggestions. The knowledge is amazing.
~ John in Utah
Here We Go
Another place you'll find those 9/16-18 bolts in on stovebolt main bearing caps.
