3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#1567649 01/08/2025 4:12 AM
What basically is the best way to assemble the rear crank. Two piece seal in a V-8 chevy without leaking oil?
Ol'55 #1567654 01/08/2025 4:36 AM
1. Make sure the seal surface on the crankshaft is pristine.
2. Follow the installation instructions in the service manual to a 'T'
3. Consider getting the block machined for a full circle modern seal. (Don't forget 1. above)
Ol'55 #1567928 01/13/2025 2:54 AM
H Online: Content
Unless the Chevy V8 is a late model with a full circle seal already there, there's no way to run one on the older types with the big flywheel flange. It's possible to weld up a damaged seal surface and regrind and polish it to original diameter, but it's cheaper to buy a new crank. Stick with a quality 2 piece seal like Victor or Fel-Pro, not the cheap offshore knockoffs a lot of FLAPS sell. Make absolutely sure the main bearing clearance is down to minimum specs to keep the crank from bouncing up and down on the new seal.
