| | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 18 | Hello all, Our home town had two body shop supply sources for years. One sold DuPont and the other Ditzler/PPG. Both have closed and the nearest source is now an hour and a half drive. Do any of you folks know of an online source for quality primers, high builds, and finish paints? Poking around the internet I found TCP Global. Their product line is called Restoration Shop and I wonder about the quality of those products. Anyone have a favorite online source and product line? Any thoughts would be much appreciated! | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | | | | | | Joined: Feb 2020 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 18 | | | | | | Joined: Feb 2016 Posts: 2,010 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 2,010 | Grandpa C., the only brick and mortar store I buy automotive paint from is "Painters Supply and Equipment", they have a few locations here in southern Michigan and maybe Ohio? They list 16 locations in Michigan on their website
| | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | here in Alaska, Carquest carries PPG products, and NAPA has their own line with Martin Senour paints. I've used the NAPA/M-S epoxy primer with good results. You might check with your local Carquest or NAPA stores about paint. O'Reilly can also get PPG products, but they will probably will have to order it in. I suppose Carquest and NAPA may have to do the same.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,538 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,538 | As far as epoxy primers and high build urethanes, I have used gallons from Eastwood. It’s decent paint, the’ll ship it to your house and it’s reasonable priced.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2020 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 18 | | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Southern Polyurethanes has epoxy primer, solvents, hardeners, urethane in solid colors, clears, etc. High quality products at reasonable prices. For a more local source to you, Auto Rod Technologies is in SW Michigan, they carry the SPI line as well as other bases, and can mix/match colors for you. I just ordered from them the day before Christmas and had the paint here in Maryland in 3 days. Technical support: [email protected]Sales support: [email protected]Phone: 269-426-6000 | | | | | Joined: Feb 2020 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 18 | | | |
