9 members (MickeyP, Otto Skorzeny, sron48, KCMongo, Nick in Manitou, mick53, Gdads51, Jaison, 1 invisible), 100 guests, and 2 robots.
Topics128,050
Posts1,055,704
#1564571 12/01/2024 6:07 PM
Hello all,
Our home town had two body shop supply sources for years. One sold DuPont and the other Ditzler/PPG. Both have closed and the nearest source is now an hour and a half drive.
Do any of you folks know of an online source for quality primers, high builds, and finish paints?
Poking around the internet I found TCP Global. Their product line is called Restoration Shop and I wonder about the quality of those products.
Anyone have a favorite online source and product line?
Any thoughts would be much appreciated!
MNSmith #1564784 12/04/2024 8:48 PM
Thank you for the info!
7
7 Offline
Grandpa C., the only brick and mortar store I buy automotive paint from is "Painters Supply and Equipment", they have a few locations here in southern Michigan and maybe Ohio? They list 16 locations in Michigan on their website
here in Alaska, Carquest carries PPG products, and NAPA has their own line with Martin Senour paints. I've used the NAPA/M-S epoxy primer with good results.
You might check with your local Carquest or NAPA stores about paint. O'Reilly can also get PPG products, but they will probably will have to order it in. I suppose Carquest and NAPA may have to do the same.
Grandpa C. #1564794 12/04/2024 11:09 PM
AD Addict & Tinkerer
As far as epoxy primers and high build urethanes, I have used gallons from Eastwood. It’s decent paint, the’ll ship it to your house and it’s reasonable priced.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks everyone!
Southern Polyurethanes has epoxy primer, solvents, hardeners, urethane in solid colors, clears, etc. High quality products at reasonable prices. For a more local source to you, Auto Rod Technologies is in SW Michigan, they carry the SPI line as well as other bases, and can mix/match colors for you. I just ordered from them the day before Christmas and had the paint here in Maryland in 3 days.
Technical support: [email protected]
Sales support: [email protected]
Phone: 269-426-6000
MPandC #1567850 01/11/2025 3:43 PM
OK and thanks a bunch!
