4 members (1955 1 Series, Barney1951, Otto Skorzeny, 1 invisible), 44 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#1567375 01/05/2025 12:11 AM
When I acquired my 1957 GMC Napco from my sister, my brother-in-law suggested I try to find and install some front locking hubs. I've searched and searched. I can't seem to find anything which might work with my front NAPCO hubs. Does anyone know correct part #'s and/or brand names I should search for? I've attached a couple of pictures of my front hubs.
1957 GMC 100 * Line Built Napco * Pontiac 347 * 89" Stepside * Purchased new by Grandfather from my Father's dealership in 1957.
1967 Camaro RS Convertible
1968 AMC Rebel
1966 Ford F100 Crown Vic swap
1968 Mercury Cougar Barn Find
GrandpasJimmy #1567377 01/05/2025 12:22 AM
When you say "lockers", are you talking locking hubs, or locking differential? Do you know what axel housing and differential you have in there now?
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
GrandpasJimmy #1567382 01/05/2025 1:07 AM
I meant locking hubs. It has the line built Napco set up including the "Napco" embossed front axle. Apparently during my research, I need to pull a hub off to check the spline count as well. There are some Warn locking hubs out there, just not sure which part #'s I should focus on.
1968 AMC Rebel
GrandpasJimmy #1567389 01/05/2025 2:27 AM
Crusing in the Passing Lane
The spline count and mounting bolt pattern should help you find the correct hubs. Did you call Warn?
Ed
GrandpasJimmy #1567397 01/05/2025 3:32 AM
That design of hub went obsolete a LONG time ago. I'd be surprised to find that anyone makes a compatible lockout to work with it. Back when NAPCO was making 4WD trucks, they weren't toys. They worked for a living, mostly off road all the time, and a disconnector hub just wasn't needed.
Warn locking hubs would be WL-15828 or M-18.
The PDF is an old Warn brochure, go to note 1. The Napco drive flange will cross to GMC drive flange 15828.
EdPruss #1567406 01/05/2025 11:59 AM
Once I get the spline count, I'll give them a call. Thanks Ed.
1968 AMC Rebel
Jim, thanks for the part numbers. That really helps as It gives me a a starting point. I utilize "searchtempest" and found a set of Napco M-21 on Craigslist in Los Gatos,CA yesterday ($2,000....yikes). Hopefully, IF I ever find a set of m18 they will be somewhat reasonable. If anyone stumbles across a set, let me know, Thanks!
1968 AMC Rebel
FWIW - Here is a free PDF of an early Warn Manufacturing document that gives a bit more detail about the various locking hubs for many vehicles, including the GMC Napco equipped trucks. Just a bit more info to add for anyone interested. wink
~ Dan
1951 Chevy 3 window 3100
Dan:
Good info, thanks. My experience with the NAPCO stuff is that you need to know exactly what you want. It appears that configurations for the same year can vary just enough to make a difference at times.
I thinking that at the time NAPCO (Northwest Auto Parts Company out of Minneapolis) was not exacting in documentation.
don
Donsz #1567814 01/10/2025 11:49 PM
I pulled the 8 bolts and center bolt off the end of my 1/2 ton hub. I now have a better understanding of what I need to search for. Mine is a 16 spline, 3 5/8" outside diameter hub with eight mounting bolts. Not much out there other than a couple of them being rebuilt on youtube.
Anyways, like my search for a 1957 GMC Operator's Manual (comic book style) continues, so will my search for these obsolete hubs.
1968 AMC Rebel
If you happen to have a dep pocket and a very skilled machinist handy, it might be possible to adapt something newer and more available to your hubs.
Here is a PDF from Mile Marker 11026-01 could work.
jimgmc #1567905 01/12/2025 4:52 PM
Jimgmc, Thanks for the info....I'll be calling them Monday morning.
1968 AMC Rebel
