7 members (Hanks custodian, 2-Ton, TUTS 59, Otto Skorzeny, festerhairball, HandyAndy, dt235sd), 83 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
#1567344 01/04/2025 5:27 PM
Hi, I am new to these old motors. I have a 270 I am installing in my 53 1/2ton GMC I removed the bell housing, flywheel etc to install a new clutch and pressure plate and bearings. Of course we rotated the motor to remove the bell bolts, My question is how do I figure out the correct position to reinstall the flywheel, in order to time it ? Sorry if this has been ask before. I did several searches and couldn't find this info.
We were thinking we could bring the #1 piston to top dead center, and line the flywheel up with the marking on the flywheel, But we aren't even sure of the pistons. Do they run in order front to rear 1-6 ?
Any help would greatly be appreciated!
Thank you!
1953 GMC 1/2-ton Long Bed
with a 248 engine
Follow the resto in the DITY Gallery
Check your PMs- - - -A Chevy six has dowel pins in the crankshaft flange that won't allow the timing marks to get misaligned, and I believe the GMC is set up the same way. I've got a 248 disassembled in the shop- - - -I'll check it to see if the crank is doweled the same way. Cylinders are numbered 1 through six, starting at the front.
Your method of turning the engine to TDC on #1 with the valves closed and lining up the timing mark with the pointer would work. But If you just put the flywheel in place and the dowels don't all line up, just turn it 1/3 rotation and try again. If that still doesn't work, 1/3 more turn and it should go right on. No real need to turn the engine to any specific position. I just drilled and tapped some crankshaft snouts using a flywheel to hold them and just turned the crank till the dowels lined up with the flywheel.
It took longer to type that than to actually get them together.
Thats what I was going to say when I first read this. If thats the flywheel that came off it, there should
only be one way it will go back on.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I have a 270 flywheel that I removed from a 57 GMC myself. I just measured the bolt circle. One of the holes is offset. If you install all 6 bolts, there is no way to put it on wrong.
Bad news if you are trying to use your '53 248 flywheel. It has 4 bolt holes. Depending on the heritage of your 270, it likely has 6.
Crusing in the Passing Lane
I seem to remember someone redrilled their 4 bolt flywheel to 5 bolts, no need to do that on yours, Joe.
Ed
Before you mount it, paint the flywheel engine side black. Then use a fine artist's brush to paint the BB (5 degrees before TDC) and the U|C (TDC) marks white. On mine I counted 56 teeth (1/3 turn) either direction from the TDC mark and used an engraving tool to make "TDC" marks for cylinders 2&5 and 3&4. Paint them too. I don't know what I'll ever need them for, but I'm ready if I do.
