3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1567242 01/03/2025 4:02 AM
I am restoring a 53' Chevy 1/2-ton truck model 3100. The rear suspension on this truck has a double leaf spring configuration that I cannot find in any of the parts suppliers online. It also does not show this configuration in the factory assembly manual or the shop manual for this year series. I have attached two photos of the rear axle and springs. Anybody have any ideas on what this is?
Those look like aftermarket overload springs (the shorter leaves on top.) They were designed to contact bumpers on brackets bolted to the frame after the main springs deflect a bit. The idea is that the truck rides like a stock suspension, but after the rear end squats a bit from a load, the second set of leaves engage to keep it from squatting all the way down to the frame bumpers. None were offered as stock springs for a '53 3100.
AD Addict & Tinkerer
I believe Kevin is right. Although the factory did offer overload springs for your ‘53, they don’t look like that. My ‘52 3100 came with overload springs and they appear to be factory, listed on page 434 of the 1929-1954 Chevrolet Master Parts and Accessories Catalog under 7.503, Spring Assembly, Rear section. 47-54 Util 6 leaves (Aux Springs) Part 604934.
Factory overload spring
Factory overload spring mounted
Chevy parts catalogue
Phil
Project Journals
Stovebolt Gallery Forum
U
U Online: Content
I have a similar overload spring on my 1946. You can see where the ends of the springs touch the bumpers on the frame above them.
~ John in Utah
Here We Go
Follow in his DITY Bay
I've got an early 1950s GMC long bed 1/2 ton frame with an almost identical overload system on it.
OK. That explains why the replacement rubber bumpers I see offered by parts suppliers don't look like what I have. Since this is going to be a show truck and likely never see a load that would require the overload springs, I think I will just leave the replacement bumpers for these springs off all together. If the overload springs do contact the frame for some reason, I can always add them back on from under the truck.
If I was trying for a show quality I'd take them off, should be able to find someone that could use them.
BC
1960 C60 pasture art
Just remove the overloaders altogether. They will serve no purpose.
1950 Chevrolet 3100 (Ol' Roy)
Leave them on if they are still good they don’t make a difference until you put some weight in the back then they stiffen up the origional suspension to make it easier on the truck.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
B Online: Content
Just another 50 pounds to haul around.
