2 members (Stovebolt48, Southerntruck), 73 guests, and 1 robot.
Topics128,049
Posts1,055,635
#1567197 01/02/2025 7:46 PM
Though my old AC fuel pump is working just fine, just wondering what’s a good replacement for when/if failure happens.Here’s a couple pics of the AC
Running a ‘62 235
Perhaps a Carter M2999 ?
Craig
That looks like a non-rebuildable crimped body pump, likely not an original. I'd suggest finding an old rebuildable one with the glass filter bowl on it and a rebuild kit from Then and Now Automotive.
The Filling Station has new ones available as well. Their PN FS-215G or FS-49G depending on fuel line orientation. Can't vouch for the quality of new pumps, though.
Yes. Do what Kevin said. I'd call Then and Now and ask them if they might be able to rebuild the one you have. They did a great job on mine after two Chinese ones failed in short succession.
I think either Jim Carter or The Filling Station has "new" glass bowl types for sale. Somebody on here got one and its been working for him.
If not, find one on ebay and send it off to www.then-now-auto.com
1950 Chevrolet 3100 (Ol' Roy)
Otto I don't think anyone can reliably rebuild a pump that's crimped together. Has to have screws holding the body halves together.
You're probably right. Maybe they have a special tool or something, though. I'd ask just to see.
Sorry for the late reply. Been driving for a few hours. Since I've had such great luck (30+ years) with my current pump, was hoping to simply find an exact replacement just to have sitting in my truck parts cabinet. Thanks for the ideas and who to contact if I decide to venture towards the glass bowl style.
Craig
I bought a glass bowl pump from Jim Carter and it is American made. So far it works fine. Instruction after install is to let vehicle idle for 15 minutes before driving. Pump is installed on 54 235 engine.
Curmudgeon
Curmudgeon
AC superseded pump models over time. The government forced manufacturers to stop using glass bowl fuel pumps (breaking during an auto accident). Around 1951, the pump arm length was changed to increase pressure by 1/2 psi. The Master Parts book lists angled output for 1937-54. The 1971 Chevrolet Truck Parts lists 1936-1957 as 5593247 and 1958-1962 as 6415726 which are the AC supersede replacements which have the crimp tops. As much as I like Carter, the M2999 is not a pump that Chevrolet used when building a new truck. A 1962 235 engine in a 1950 Chevrolet truck means the truck is not original so the owner is at liberty to use whatever he/she wants.
Ethanol gasoline can ruin a perfectly good working NOS fuel pump. So, if you live in an area where non-ethanol gas is hard to get, you want a pump that can withstand ethanol.
Let's say you find a used pump that will work on your engine, and visually looks like what you want, chances are it is worn out inside. The pump cam rides on a pin or pivot that is pressed/attached into the pump housing. After billions of operations, the cam, pin and housing have wear. So, to make this pump work well it needs to go to a professional rebuilder who can replace or fix worn parts and install ethanol tolerant diaphragm, seals and valve. The last time I looked, rebuilders do not repair Carter pumps. This may have changed by now.
You can buy new pumps from your FLAPS but these come from Asia. Finding a good one is hit-and-miss (i.e. reliability is suspect). If it fails under warranty, you get another one without warranty. If the replacement fails....
I bought a new pump from my FLAPS but I opened the box to make sure it was the "appearance" I wanted. I also bought a NOS AC pump just in case.
