2 members (Hotrod Lincoln, 2-Ton), 149 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
I find that even with tri-focals, decent light, and holding my head "just right" that reading standard calipers and micrometers is getting extremely difficult. The digital versions of these seem appealing -- however, I have questions concerning their accuracy and resolution. Anyone out there with first hand experience using these products? Any and all input would be greatly apreciated, including but not limited to manufacturer and model#.
twe56 I use these things every day. I find that the dial calipers are easier to read for me than the digital ones. The digitals are very sensitive to any movement and will change when removed from the object being measured and give a false reading. Both types are very accurate and either will do the job. You can buy a good 6 inch dial caliper for about $30.00. Hope this helps. BTW I have tri-focals so I know what you mean. Weeds
Weeds, thanks for the reply.
Moderated by  MNSmith
