| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2024 Posts: 221 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 221 | I purchased a running 46 Chevy truck. Needs a little love but is drivable. I want to put the mirrors on the door hinges. I have the pin loose on drivers door. I used pb blaster and hammer taps then a punch. My question is do you guys recommend grease or anti-seize on new pin in case it needs to come out again? Thanks
| | | | | Joined: Sep 2009 Posts: 6,024 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,024 | Ponchogl - First off Welcome to Stovebolt and congrats on your recent truck purchase!  Your post may get better answers in a more specific forum, but is general enough to stay here for the time being.  Folks should be along to provide suggestions and thoughts on your question soon. Once again, Welcome!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2000 Posts: 5,239 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,239 | You need to keep them greased so the door opens and closes without a lot of effort. With that being said, keep an eye on the pin in case it wants to back out. My '37 uses a similar hinge setup and I use mirrors on both doors. The drivers top pin kept moving upwards till I rebuilt the hinges. I believe the loose hinges kept the door moving which worked the pin out. Since the rebuild, the pin has stayed in place, even with the grease. | | | | | Joined: Dec 2024 Posts: 221 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 221 | I understand the need for lubricant. I was meaning the top part of pin with grooves would be ok with grease or if anti-seize would be better if the need to remove pin for any reason in the future. I have read some guys have to use a torch and I would like to avoid that if possible. Thanks | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Rust and wear (wear shows as grooves on the pin) make hinge pin removal difficult just like kingpins on the front suspension.
You want grease where parts move against parts. Grease makes the parts last longer. When the hinges and pins were new, the grooves helped to hold the pin in place, so grease is not necessary at the grooves. Some greases evaporate/decompose over time so periodic maintenance is needed. I've seen clothing spotted by brushing up against a hinge so the grease that may last longest may not wash out of clothing. On a farm, where many of these trucks were used, the farmer selected whatever oil/grease he/she had at the time and applied it in the easiest/quickest manner possible.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Dec 2024 Posts: 221 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 221 | Great. Thank you so much I will do it this. Someday I will repaint the truck after I get the the other little issues fixed and I may have to remove pins. At that point they shouldn’t be in as long they have been. | | |
