| | | Forums66 Topics128,261 Posts1,058,341 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2024 Posts: 1 Moderated | | Moderated Joined: Dec 2024 Posts: 1 | Hello...Just joined this site...wow , is there alot of info on this site...Picked up a '51 1/2 ton shorty this spring...Got it running after 20+ years of sitting...in the shop for the winter doing some usual bodywork first ..driver's floor and some inner/outer cowl work...Have bought some replacement panels from Billstruckshop in Ontario and I know about Scott's super trucks in Penhold Alta. as well as Ace of speed in High river...just wondering if there is any others that i haven't heard about for used/new parts?...Not going to make her a show truck...just planning on getting her roadworthy and plan on sealing the original patina eventually...Ed...will post a pic of truck when i get a chance  | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Welcome to the sight. If you want to keep your suppliers in Canada there is also KMS, They have free shipping for over $99, and under 50 pounds, with some restrictions. If you want to go outside of Canada there are a ton of parts suppliers south of the border. Some I have used more often are, Jim Carter, The Filling Station, Brothers, and Classic. But there a lot more. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Hello...Just joined this site...wow , is there alot of info on this site...Picked up a '51 1/2 ton shorty this spring...Got it running after 20+ years of sitting...in the shop for the winter doing some usual bodywork first ..driver's floor and some inner/outer cowl work...Have bought some replacement panels from Billstruckshop in Ontario and I know about Scott's super trucks in Penhold Alta. as well as Ace of speed in High river...just wondering if there is any others that i haven't heard about for used/new parts?...Not going to make her a show truck...just planning on getting her roadworthy and plan on sealing the original patina eventually...Ed...will post a pic of truck when i get a chance  Lordco had brake cylinders off the shelf for my 1 ton, KMS Tools, The Old Car Centre. Super55 has great suggestions also that I’ve used. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Bought a master and wheel cylinders for my 49. off the shelf at NAPA in Victoria. But that was 15+years ago.. | | |
