4 members (39Master85, Mike B, Phak1, wvstovebolt), 111 guests, and 4 robots.
Topics128,129
Posts1,056,698
Members48,454
Moderated
Moderated
I can't believe it's been 8 years since I was last on this forum. At that time, I documented the build of my 1958 Apache pickup. Thought I would give everyone an update although I don't know if anyone will remember it. As a reminder it has a .040 over 261, custom 2 deuce EFI system, vintage McCulloch supercharger, close ratio 3 speed transmission, and a gear venders overdrive. I am happy to report that the truck is still running very well with hardly any issues, and I have put approx. 5000 miles on it. It also survived a shop fire during this time. Thanks for your time, Diceman
Last edited by Gdads51; 12/30/2024 3:02 AM. Reason: Fix link in text box to allow pic to show
diceman1950 - Did you register under a new member name??? I recall your truck from back then and seems you used to post under “Diceman”.
Isn’t this you posting on your truck in the HiPo Shop???
~ Dan
1951 Chevy 3 window 3100
I gotta ask...
Why are there dice in the fuel filter?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Any chance you could remind us about the EFI set up you have?
Mike
So, you're asking 'Diceman' why he has dice in his fuel filter?
I struggle to think of a single, more self-answering question. smile
I have no idea who Diceman is, but with dice in his fuel filter, he is already cool by me.
Dice probably works as good as cow magnets.
BC
1960 C60 pasture art
Curmudgeon
Curmudgeon
They had Wireless EFI 8 years ago?
B Online: Content
They have wireless EFI now?
