10 members (Bruce 1954-4100, frogfarmer, DennisM, Joe H, Joe Lowe III, Shade Baby, 3B, Oswald, Cosmo, 1 invisible), 73 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
Is there a trick to adding these aftermarket knobs to the cowl and side vents? They’re so loose.
Daniel
1949 Chevrolet 3600
If you're not worried about taking them off again, use some epoxy inside the pocket. Not enough so it oozes all over the place when you put them on, but enough to make contact with the lever. Be sure the lever and the pocket in the knob are clean and oil-free.
I use Black RTV. It holds just fine and it can be taken off if you ever need to.
Moderated by  ndkid275, Phak1
