1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
I am struggling to put the clutch fork back on . Do I have the spring in wrong? I also read the omega like opening should be at 10 o’clock towards the throw out bearing. Hopefully I can snap it back on with just the t5 tranny out
I don't think you have the spring in wrong, it just has to snap over the ball. Although it looks like the left side of the spring in your first picture may be bent down a bit too much. It should stand forward like the right side does. Maybe the ball is already down in the socket and the spring isn't retaining it. You could remove the ball and try fitting it on the bench to check for the spring being the proper shape.
It should snap in with just a little force. I recall putting mine in after the tranny was in place and slipped the fork behind the throwout bearing and pried on the end of the arm where the clutch linkage attaches to get it snapped in place.
Wow as always great advice. I will take the post out and see what happens.
Rick
Put in a new retainer and all went back together as it should
thumbs_up
