2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2024 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 236 | My 56 3100 truck has a 12 volt generator. It had a voltmeter in it below the dash that showed good voltage when i got it. But in the old cluster only the fuel and oil guage worked so I replace the cluster with a new one and removed the under dash instruments. The new ammeter always shows below the middle mark on the the new guage indicating low charging. It's caused no problems and I've gotten no indication that there is low charging going on. I'd like it to show an accurate reading. Anything I can do to fix it?
1956 3100 three speed 6 cyl. Stock with a few upgrades. | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Exactly how is it wired? As in one side goes here other side goes here.
Does all of the positive go there meter from Battery to all electrics.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Is the new cluster wired correctly according to the factory wiring diagram? Jerry
| | | | | Joined: Apr 2024 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 236 | Thanks for the directions. I will have to take a look. I didn’t do the installation.
