7 members (Peggy M, RoadsScholar, dt235sd, Otto Skorzeny, Bill Hanlon, cmayna, 1 invisible),
145
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15658 10/31/2002 11:26 PM | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | I am going to be buying a tach pretty soon to put in my truck. My question is: what is the safe rpm for a stock 307 V8? Not that I am going to winding it out all the time, but just to have an idea on the limit.
Aaron | | |
#15659 11/01/2002 12:29 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Depending on what condition the engine's in, and how it's built.
If the bottom end's balanced, with forged rods and lightweight pistons, a mild to 3/4 cam, and adequate intake and exhaust, then you should have absolutely no problems pulling 5500-6500 rpm. And no problems holding 3000-4000 rpms for extended periods of time.
On the other hand if none of the above applies to the engine, and there's significant wear on the bearings, rings, etc., and intake and exhaust are stock, then you'd do very good to pull out 5000 rpms.
Maybe others can add more insight.
-ftyler | | |
#15660 11/01/2002 6:06 AM | Joined: Sep 2002 Posts: 72 Member | | Member Joined: Sep 2002 Posts: 72 |  howziit guys! stock 307 motor? JMO, i would set MY tach needle at 4500rpm, for starters. when you get used to your truck/307 motor, you will KNOW where to set that redline.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
