| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Well, my frame is painted and I'm getting ready to start reattaching everything. I'm going to use the original nuts and bolts where ever possible. I stopped at Sears yesterday thinking I would get a tap and die set to clean up slightly buggered threads. Next to the tap and die sets they had a set of similar tools specifically for dressing nuts and bolts. They looked as if they would be easier to use than taps and dies for what I want to do. Since in 53 years of my life I have needed a tap or die maybe 5 times, I was interested in this set. I'd like to hear comments from the more experienced mechanics. Thanks in advance (design).
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Check Lareoke's website. He uses a vibratory parts cleaner and various metal treatment kits from Eastwood and if I was doing what you are, I would treat all my nuts and bolts that way. It makes them like new.
His website is all over, check links or previous posts, or profiles. Good luck. Others will comment on the die set I am sure. I want one too.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Dressing sets are usually junk. They are considerably cheaper, and there is a reason for that. I tried to used a dressing set on one ocassion, the thread I was trying to fix was harder than the metal in the dressing set - basically destroying the die.
If you are worried about price, and you don't use them very often, just buy the tap or die that you need. They are avaialble separately.
Don't buy a tool that is insufficient to do the job. | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I have a nice Craftsman tap and die set that I bought from Sears a few years ago.. When doing the restoration work on my truck I used the set many times.
If you are planning to re-use as many bolts as possible, I am sure you would get plenty of use from a good set.
I have tried the dressing tools as well. I agree with Vaughn. If the dressing tools were so great, the tap and die makers would be out of business.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Thanks guys. This was exactly the kind of feedback I was hoping for. I appreciate it.
Jeff Nelson
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | For a quick thread fix on bolts, you can also get thread files. About 8 inches long with a square cross section. One file has 8 different thread sizes, 4 on each end. Don't have any idea about cost, but they are wonderful tools.
Fred 52 3600 69 C-10
| | | | | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | I bought the Craftsman 20 pc. Master Rethreader and have used it quite a bit. I also have the vibrating tumbler thingy from Eastwood, and you need the rethreader to clean out the groves in the nuts and bolts after they're shiney.
Jim
