0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#1565249 12/10/2024 9:01 PM
V
VEW
Offline
V Offline
I need to go from a 7/8” hose fitting on my water pump into a 3/4” hose into my heater core. I cannot locate an adapter.
I have 3/4” connector. Should I just build up one side of it with something to make it fit? If so, what?
I must be missing something. Why does this need to be so difficult? It’s just a blankety blank water pump!
Thanks for your guidance.
~ Victor
1957 3100 - moved on
I lubed the end of the hose with some coolant and was able to just stretch the 3/4" hose onto the 7/8" nipple on the water pump in my 58.
Might be worth a try.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Alternatively, you could get something like this:
https://a.co/d/f7gEc0B
Finally, the inlet/outlet on a lot of water pumps are just NPT nipples. You might be able to unscrew the 7/8" one and replace it with a 3/4" one.
VEW #1565258 12/10/2024 10:46 PM
V
VEW
Offline
V Offline
Thanks for the advice. I’ll give it a go!
~ Victor
VEW #1565261 12/10/2024 11:29 PM
7
7 Offline
You could also warm the hose with a heat gun to help ease it onto the fitting.
V
VEW
Offline
V Offline
Tried the heat gun but the reinforced hose did not give enough. I ordered the adapter. Thanks again for your help!
~ Victor
If the pump is NPT, you can install a 7/8" X 3/4" NPT bushing, then a 3/4" NPT to barb.
V
VEW
Offline
V Offline
Thanks Mark. NPT would be too easy 😊. It’s a nipple.
~ Victor
