I need to go from a 7/8” hose fitting on my water pump into a 3/4” hose into my heater core. I cannot locate an adapter.
I have 3/4” connector. Should I just build up one side of it with something to make it fit? If so, what?
I must be missing something. Why does this need to be so difficult? It’s just a blankety blank water pump! Thanks for your guidance.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery 1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter
Tried the heat gun but the reinforced hose did not give enough. I ordered the adapter. Thanks again for your help!
Thanks Mark. NPT would be too easy 😊. It’s a nipple.
