3 members (Hotrod Lincoln, Pete O, 1 invisible), 309 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
Page 2 of 2 1 2
You can still buy the 3600 fuel tank from LMC for the 53.
Why wouldn't that work in a 47-48?
Elmo - Which LMC tank are you referring to please? headscratch For the reproduction between the frame rail tanks for AD series trucks for the 1947-48 pickups and 1947-55.1 Suburbans and Panel trucks, the ads I've seen all (except LMC) indicate they are for 1/2 ton trucks only.
~ Dan
1951 Chevy 3 window 3100
Gdads51 I was referring to the gas tank that mounts in the cab not under the bed.
The height of the 3/4 ton frame rail is less than the height of the 1/2 ton frame rail. The tank mounts fit into the frame rail. I tried to mount a 1/2 ton tank to my 3/4 ton truck. Don't fit.
Elmo - Thanks for the clarification. wink
~ Dan
Page 2 of 2 1 2
