Brrrr
place holder
4 members (papas52, TexasFarmTruck, 55shaker, Otto Skorzeny), 216 guests, and 3 robots.
Topics128,271
Posts1,058,414
Members48,485
#1565153 12/09/2024 12:36 PM
Gents, I just ordered a new water pump for my ‘61 261 that I will need to press into a short shaft pump for clearance.
Does anyone know the correct measurement that I need to press it to? I want to confirm my old one is correct and press the new one before removing the current one.
Chris
You’re asking how deep to press on the pulley?
I have a short shaft pump on my 235 I can measure this evening if you like.
1951 3100
Yes! I’m trying to figure out how far to press it in.
Mine appears to be 4 1/8-4 1/4 from block to front (flat part) of pulley.
By flat part, you mean the surface the fan bolts to?
There might not be a RIGHT answer here. The key is having radiator clear and the pump pulley aligning with balancer.
Either way, I can measure mine and share.
1951 3100
Moderator, Electrical Bay
You might want to check on one thing. There were pumps made by different people and in different ways. About 15 years ago a friend tried this only to discover the long pump's shaft on the one he bought was shouldered...meaning you could only press the mounting flange down so far and it bottomed. We figured it was to make assembly faster and less prone to error. Just a suggestion. Some of them were not shouldered.
~ Jon
Moving the flange back solves one problem and creates two others. The fan blades will hit the balancer unless you run a very small diameter fan, and the fan will be off center on the radiator.
Looks like mine is right at 4 inches from fan mounting surface to block.
1951 3100
ODSS President
ODSS President
All too true! I ended up using a spacer on the pump flange and a non stock fan with minimal blade pitch. I only overheated twice in fifteen years and 80 k miles or so. Both incidents were on long very warm summer trips of 400+ and 300+ miles where traffic was stopped dead. I ended up turning the heater on full with the heater fan on high. I suffered greatly but thankfully traffic moved and the truck and I were somewhat back to normal.
~ Cosmo
1949 Chevy Half Ton
Hotrod,
I have an electric fan due to running a larger radiator.
JW51,
I measured with pulley on since it is still on the truck
Chris
We must be talking about different pulleys. My measurement is also pulley on.
1951 3100
I will measure and take a picture. I’m not convinced my pulley is perfectly inline. I’ts close…. 1/8” isn’t too far off.
Yeah the pulley is different. Mine is an “off the shelf” short shaft pump purchased years ago from Jim Carter. I can grab a picture later.
I measured a couple different times. I wouldn’t call it 4-1/8”. Definitely more like 4”
1951 3100
I wouldn’t think the “face” of the pulley would be that much thicker. I bought mine already pressed as well, but it seems slightly longer. I think 4” will be a better pulley alignment.
1 Offline
How far you press the flange is entirely dependent on which pulley you use. I have used a factory V8 pulley that has a shorter offset than the factory 6-cylinder pulley. That makes room for a 6-blade truck fan that you can remove without removing the radiator first. You'll find that if you use a 16-inch fan, you'll have to drop the radiator several inches for the fan to clear the lower hose connection.
Later, I added AC and rather than trying to drive the fan, alternator and AC compressor off the one water pump/fan pulley, I got a 2-shiv crank pulley and used a V8 2-shiv water pump pulley for an air-conditioned V8 with short shaft water pump. Whichever V8 pulley you use, you will have to press the flange an additional 1.1 inches onto the pump shaft. Don't use my figures but measure it yourself for your application. The distance that matters is from the block mounting surface to the pump's pulley mounting surface. That dimension has to make the shivs on the crank and water pump line up exactly.
If you are using an after-market short shaft pulley then its offset will determine how far to press. You get one chance to get it right because it's really hard to press it back out with a regular shop press (at least with my 20-ton) and a puller won't move it in my experience. If you go too far you'll have to shim it back out.
1951 3800 1-ton
In the DITY Gallery
