3 members (NJC, HandyAndy, Oswald), 129 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#1564899 12/06/2024 2:16 AM
AD Addict & Tinkerer
My second time spraying urethane prime, and I’m struggling to get it to lay flat. It sprays like its too dry but does flatten (not completely) after it drys a bit. I’m using an Eastman 2k urethane primer in a 4 to 1 mix sprayed from an Eastman Contours 2 spray gun with a 1.7 tip. The tech sheet recommends a 1.5-1.7 tip and sprayed at 25-30 psi at the gun. I have a pressure regulator attached to the gun and tried 25 to 30 psi. The temperature in the garage at the time I sprayed was about 55°.
It’s not a big deal as I’m block sanding it anyway, but you’re supposed to be able to use it as a sealer then top coat it without sanding, so I’m sure my technique needs to be improved.
The pictures are immediately after spraying, then after it settled a bit, in addition the tech sheet.
Any suggestions would really be appreciated.
Immediately after spraying
After settling a bit
Tech sheet
Phil
Project Journals
Stovebolt Gallery Forum
It has been a long time since I sprayed and was going to say you need more pressure but I see the pleasure is lower for a hvlp gun.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Maybe lay it down a little heavier (slower gun travel?)
Also your data sheet suggests using up to 20% reducer. That will help it flatten.
I haven't sprayed urethane primer, but adding some reducer sure helped with my top coat, which says it can be sprayed right out of the can.
7
7 Offline
55 degrees is pretty cold for spraying auto finishes but that would normally result in sags, runs, very long flash time. What was the temperature of the metal? did you have a lot of air movement? It appears that you have too high air volume/too little liquid, or the gun is too far from the panel or moving too fast across the panel. I would cut the mix with the fast reducer due to low ambient temperature and practice on some disposable surface. The PPG epoxy primer that I have used lays very smooth and needs zero sanding, I use a conventional siphon gun at lower pressure than recommended or an airbrush.
I had a similar experience and was advsed to lower my pressure which may align with 78buckshot's comment about too much air volume. It seemed counter intuative to me but I do not hav much experience.
1949/50 3600 Project
Follow in Project Journals
If I were painting that, I would turn up the air pressure to get the material to atomize more. If it was still giving me issues, I would reduce the product a little, if I could.
