2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
With a 216 style w/pump mounted on a 235 with an adapter I get leaks at the two bolts going through the assembly. These are the holes under the half moon opening. Anyone have a solution? Thanks
1948 1 ton
AD Addict & Tinkerer
I had the same issue and I reversed the two bolts, put a dab of silicone under the head which sealed the leak. I believe the leak path was through the threads between the nut and bolt.
Let it dry first 24 hours before refilling with antifreeze.
Here is the post where I discovered and resolved the issue.
Phil
Project Journals
Stovebolt Gallery Forum
Many thanks. I'll give it a whirl.
1948 1 ton
You might also want to use Permatex Seal Lock on the threads. It stands up to gasoline, coolant, and oil.
1950 Chevrolet 3100 (Ol' Roy)
