2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#156419 02/11/2003 4:56 PM
If you have 2 exact pieces of metal how much stronger is stick welding to brazing. Have both would like a mig but maws says old dad spending to much money on 59 Apache. Would get rid of her but the title to the Harley is in her name also. Sure would miss the bike!
#156420 02/12/2003 4:29 AM
I would say the stick (SMAW) is at least twice as strong as a brass weld. I can find out the tensile strengths of each, but it will take a little time. The 7018 rod is 70,000 psi tensile strength, while the 6011 is 60,000 psi--the first two numbers in the rod ID is the tensile strength. I am not sure about brass tensile strength, but I do know brass is not as hard as steel.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#156421 02/12/2003 6:03 AM
Racecarl's right. But your decision will rely on what you're welding. Body sheet metal? for years the body shops brazed everything. It was easy to smooth and taper out, but the flux can cause corrosion if it isn't boiled out. Frames and brackets? You need the stick. You can weld sheet metal with a stick, but it takes a lot of work to smooth things out.
Fred
52 3600
69 C-10
#156422 02/12/2003 2:14 PM
Thanks Racecar and Fred T that's exactly what I wanted to know. Still wish I could by a mig. MAWS says NOOO.
#156423 02/12/2003 10:42 PM
I don't dispute the welding must be stronger and would have to be used on anything structural like a frame, but brazing uses various formulas of BRONZE, does it not? Bronze is significantly stronger than Brass and I have repaired broken steel sword guards with brazing, and have fought and beat the he** out of 'em afterwards with no failures yet. Am very curious about further auto applications of brazing.
respectfully,
Ed Britton
#156424 02/13/2003 12:41 AM
You could always rent a mig for pretty cheap, if you get all your welding set up before you get it. I would lend you mine but I'm too far away.
Paint & Body Shop moderator
#156425 02/13/2003 3:43 AM
Junior Member
Junior Member
stick welding and brazing are two completely different animals.stick welding is fusion of the two base metals with the inroduction of a third filler metal. a correctly prepped and welded joint will not fail. the parent material will fail before the weld ever will. Brazing is bonding similar to glueing. the parent materials are never melted they are just stuck together by the brass.
Moderated by  MNSmith
