2 members (Patharr, 1 invisible),
45
Mod | | | Forums66 Topics128,090 Posts1,056,027 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | If you have 2 exact pieces of metal how much stronger is stick welding to brazing. Have both would like a mig but maws says old dad spending to much money on 59 Apache. Would get rid of her but the title to the Harley is in her name also. Sure would miss the bike! | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I would say the stick (SMAW) is at least twice as strong as a brass weld. I can find out the tensile strengths of each, but it will take a little time. The 7018 rod is 70,000 psi tensile strength, while the 6011 is 60,000 psi--the first two numbers in the rod ID is the tensile strength. I am not sure about brass tensile strength, but I do know brass is not as hard as steel. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Racecarl's right. But your decision will rely on what you're welding. Body sheet metal? for years the body shops brazed everything. It was easy to smooth and taper out, but the flux can cause corrosion if it isn't boiled out. Frames and brackets? You need the stick. You can weld sheet metal with a stick, but it takes a lot of work to smooth things out.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Thanks Racecar and Fred T that's exactly what I wanted to know. Still wish I could by a mig. MAWS says NOOO. | | | | | Joined: Sep 2000 Posts: 33 Member | | Member Joined: Sep 2000 Posts: 33 | I don't dispute the welding must be stronger and would have to be used on anything structural like a frame, but brazing uses various formulas of BRONZE, does it not? Bronze is significantly stronger than Brass and I have repaired broken steel sword guards with brazing, and have fought and beat the he** out of 'em afterwards with no failures yet. Am very curious about further auto applications of brazing.
respectfully,
Ed Britton | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You could always rent a mig for pretty cheap, if you get all your welding set up before you get it. I would lend you mine but I'm too far away.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2003 Posts: 33 Junior Member | | Junior Member Joined: Feb 2003 Posts: 33 | stick welding and brazing are two completely different animals.stick welding is fusion of the two base metals with the inroduction of a third filler metal. a correctly prepped and welded joint will not fail. the parent material will fail before the weld ever will. Brazing is bonding similar to glueing. the parent materials are never melted they are just stuck together by the brass. | | |
