| | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2024 Posts: 6 'Bolter | | 'Bolter Joined: Nov 2024 Posts: 6 | Truck is 6 lug, drum brakes all around
Intending to use it as a daily driver / cruiser
One opinion is to swap the rear end (with what, TBD) for something that’s 3.73, disc brakes and 5 lug; then make the conversion on the front to 5 lug with discs using a kit.
Another opinion is to keep all as is except converting the front to disc brakes.
Any strong opinions one way or the other from the group? | | | | | Joined: Sep 2009 Posts: 6,199 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,199 | Your question needs more background info on your truck and it's existing power plant/transmission combo before folks can give good feedback on a suggested rear end path. I looked but couldn't find any details in your previous post to know those details.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | and what is your daily commute. Since your tag is Danbury, CT its not exactly bumper to bumper in high heat conditions but it will help with the answers. If its just driving around town let us know. If you plan on hopping on I-84 and heading out of town for miles and want 65+ let us know that too. | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | Lot's of variables here. It could depend on what engine and transmission combination you currently have. A 3.73 rear end would have to come from a later vehicle which would require some spring pad relocation and driveshaft mods. It wouldn't change much from the 3.90 standard gearset in the truck. There is a 3.38 gear set available for the corporate Eaton that came with the truck. There are factory overdrives and later units available using the stock rear end. I believe in disc brake upgrades, there are 6 lug conversions available. 5 lug conversions will require all new wheels and possibly tires.
| | | | | Joined: Nov 2024 Posts: 6 'Bolter | | 'Bolter Joined: Nov 2024 Posts: 6 | It’s a 350/th350. I don’t really commute but would drive it around town, running errands, etc. Going on a trip could be three hours each way, but that wouldn’t be often (let’s say twice a month). I wouldn’t often take it on a major highway, but let’s say it’s one of those two trips a month.
I do need to get new wheels/tires, regardless.
Appreciate any suggestions! | | | | | Joined: Jan 2019 Posts: 2,244 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,244 | For that kind of a use case, you really don't need to change out the axle/brakes.
That said, if you want to make an upgrade just because, there are a few options available.
I personally put a 3.73 rear end out of a grand cherokee in the back and a disc conversion from Speedway on the front.
The 4WD S10 rear end is another popular choice for the rear. There are a few different choices, really. Though there are some other changes that you might consider at the same time.
If you want to go down that rabbit hole, I would recommend starting a thread over in HiPo to explore it. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | My 1957 has 3:38 gears, with a Chevy 348 engine. Runs great in all conditions. For a while I had a 283 (one 4BBL), that also worked fine. Sounds like you have plenty of power to work with. I got my gears from Patrick's (it is a NAPCO truck.) I also installed a dual master cylinder with disc brakes up front because of the problems with the NAPCO brake parts (they are Studebaker). I'm very happy with that choice also. don | | |
